Ik kwam zojuist deze tabel tegen;
Here is additional information to hand.
This shows Marklin product number, diameter across tread, length of axle, type.
700020: Wheel Dia: 12 mm Axle Length: 24.9 mm Design: stepped axle
700070: Wheel Dia: 12 mm Axle Length: 25.2 mm Design: stepped axle
700080? Wheel Dia: 12 mm Axle Length: 26.2 mm Design: stepped axle
700100: Wheel Dia: 10 mm Axle Length: 26.0 mm Design: stepped axle
700150: Wheel Dia: 10 mm Axle Length: 24.4 mm Design: tapered axle I guess this is the standard wheel set that comes with many Marklin items that I purchase
(Marklin DC equivalent wheel set catalogue #700580).
700190: Wheel Dia: 10 mm Axle Length: 24.8 mm Design: stepped axle
700200: Wheel Dia: 10 mm Axle Length: 24.1 mm Design: stepped axle
700230: Wheel Dia: 10 mm Axle Length: 24.4 mm Design: tapered axle, spoke wheels
(Marklin DC equivalent wheel set catalogue #700630).
700530: Wheel Dia: 12 mm Axle Length: 24.9 mm Design: stepped axle
700590: Wheel Dia: 10 mm Axle Length: 26.0 mm Design: stepped axle, DC
700600: Wheel Dia: 10 mm Axle Length: 24.8 mm Design: stepped axle, DC
E320 552 Wheel Dia: 9 mm Axle Length: 24.8 mm Design: tapered axle, DC NEM I guess this is the standard wheel set (if not RP25) that comes with many Trix items of US rolling stock
E320 551 Wheel Dia: 9 mm Axle Length: 24.8 mm Design: tapered axle, (Märklin) AC wheel I guess this is the standard wheel set that comes with many Marklin items of US rolling stock
These latter are Trix catalogue numbers (as confirmed with my dealer).
E320 389 RP25 2rail DC
Bron: Marklin-user.net, Kimball
Standaard zou dus 700150 moeten zijn, echter zijn die 10 mm. Op zich moet het dan passen. Ik zal straks nog eens gaan meten, ook de as lengte.
