Ik dank dat het handig is om een calibratie van het touchscreen uit te voeren.
Link halverwege de pagina.
Cut-n-paste:
If the touch screen does not respond to pressure, it needs to be re-calibrated. Usually the ECoS comes with a calibrated touch screen ex works.If the touch screen does not respond to pressure, it needs to be re-calibrated. Usually the ECoS comes with a calibrated touch screen ex works. Please go ahead as follows:
Push the function buttons F2 and F7 of the left AND the right throttle at the same time.
Now the calibration screen appears.
Please follow the instructions shown on the screen: Please push the occuring red and green crosses one after another by using the attached stylus. Please try to hit the crosses as exactly as possible.
Now the message "Calibration finished" appears on the screen. The calibration will be saved when you push the OK button. Now the touch screen works as it should. If the message "Calibraton could not be carried out" occurs, the crosses haven´t been hit precisely. In this case please repeat the procedure.
Jan-Peter
