iTrain Versie 3.2.5
Gestart door Freak zondag 02 november 2014, 13:29:36
iTrain Versie 3.2.5
Freak
iTrain Versie 3.2.5
iTrain Versie 3.1.3
Versie 3.1.3 (2014/10/28)
3.1.3
- Checksum error solved in BiDiB.
- Some bugs in direct DCC message generation solved (binary state long form).
- Dinamo RMU option DC 3-rail changed in XML to start with a letter.
- Bug fix: Delayed relais release for Dinamo fixed.
- Bug fix: General signal did contain two road signal states.
Re: iTrain Versie 3.2.1
iTrain Versie 3.2.1 (2015/01/04)
3.2.1
- Support for old DCC function decoder based on 14 step protocol.
- Bug fix: Dinamo functions f5-f8 could not be used as momentary functions.
- Bug fix: Reading turnout lengths was not correct if all states had the same length.
- Fix: Accessory state mappings more forgiving for wrong output specification.
- Bug fix: Transfer table did not stop at end position.
- French manual for version 3.2
3.2.0
- Properties:
  - Selection of address usage: Single, Double, Triple, Range or Extra (=Range + separate address)
  - Crossing and relay can also use multiple addresses and state mapping table.
  - For turnouts different lengths for every state can be specified in a new tab.
  - Extra unknown polarity for blocks and better RailCom direction detection in trains.
- Routes:
  - Option to check if trains have arrived in time and if not stop their route and activate the alarm.
  - Alarm state will not release reservation on next block and turnouts.
  - Extra train route option to use train type permissions in defined route. By default and for drag & drop it is off.
  - Extra block option 'Direction change forbidden' to prevent unexpected direction changes in specific blocks.
  - Strict option in route editor to assure strict order of specified blocks will be followed.
- Switchboard:
  - Long click in switchboard made less sensitive to small movements of the mouse.
  - Turnout group added so track and road items can be added to a turnout to show the reservation state.
- Boosters:
  - Diagnostics (voltage, current, temp) stored per booster object to display info in the switchboard.
  - Active booster management: Cannot reserve block with inactive booster and signal to inactive booster section will be red.
- Interface specific:
  - Full BiDiB support with UniqueIDs and features.
  - SProg devices supported with DCC generation via slots/refresh cycle, but not for programming.
  - Support for uCON-Manager as stand-alone DCC generator so you don't need a command station.
  - Support for DCC aspects for extended accessory decoders in LocoNet, TAMS, OpenDCC, BiDiB, SPROG and uCON-Manager.
  - Use framing character with D2XX driver for faster transmission of packets with BiDiB, Gbm16XN and Zimo.
  - LocoNet slots made IDLE after initialization with speed zero and no functions active.
  - Feedback grouping for Massoth defaults to 2 for A and B.
  - CS2 also supports boosters via the ID of the device, including switching on/off and showing alarm status.
  - Dinamo analog: Use internal acceleration value if speed is increased too fast (measurements).
  - Dinamo: Added support for 126 speed steps and extra functions (f13-f28 and binary states) in upcoming firmware.
- Clients:
  - Better support for Android and RoboVM for iOS in service layer.
  - Clients using less threads than the stand-alone or server instance for small devices.
  - Client has no restrictions on number of interfaces and number of items and follows the server.
- Others:
  - Turntable and transfer table: Make distinction between intermediate state and final state and show with line that it should be moving.
  - Search field added to every editor dialog at the top on the left to find items by typing.
  - Feedback system actions blocked when other button is still active. Cannot use GO when STOP is still active.
  - Better window management with multiple screens especially on OSX.
  - Extra option sort on no item in loc and wagon overview to keep original order of the editor list.
  - Possibility to remove license from computer by entering only the e-mail and no license key.
3.1.4
- Bug fix: Booster with attached relais does not change state correctly when clicking on it.
- Bug fix: Gauge not parsed correctly when default gauge is not set to normal.
Re: iTrain Versie 3.2.2
iTrain Versie 3.2.2 (2015/01/29)
3.2.2
- Bug fix: When transfer table has already correct position (no movement) the train does not start.
- Tool windows to front when starting and when double clicking on toolbar.
- Windows: itrain.exe introduced that starts itrain.jar to solve the problem with the java path not found
- Dinamo: Block linker made single threaded to prevent race conditions.
- Spanish manual for version 3.2
- Bug fix: Dropping a loc without a train on a block is not possible on client to prevent duplicates.
- BiDiB: Also read all loc addresses of RailCOM-feedbacks after initialization.
- uCON: Different timeouts for manager and s88-Master.
Re: iTrain Versie 3.2.3
iTrain Versie 3.2.3 (2015/02/14)
3.2.3
- Z21: No default receive port used so multiple Z21 command stations can be used.
- Windows shortcut: use itrain.jar directly without javaw.exe to start
- Better default initial state for signals when no type selected.
- List of all server IP addresses retrieved without using host name.
- Alternative way of retrieving hostname for server and client if no DNS available.
- Bug fix: BiDiB retrieving unknown features does not give problems anymore.
iTrain Versie 3.2.4
Freak
iTrain Versie 3.2.4
iTrain Versie 3.2.4 (2015/03/13)
3.2.4
- Only start all the active trains.
- State of feedback recalculated when option inverted changes.
- Bug fix: Changing the turnout of an item in the switchboard did not change it properly in the turnout group.
- Bug fix: Streaming of accessory state in turnout reservation incorrect.
Re: iTrain Versie 3.2.4
Aliebengalie
Mooi.....dank U..... :thumbup:
Dank voor het plaatsen, heb zojuist de nieuwe binnengehaald. :thumbup: :thumbup: :thumbup: :thumbup:
iTrain Versie 3.2.5
Freak
iTrain Versie 3.2.5
iTrain Versie 3.2.5 (2015/04/28)
3.2.5
- Wrong text in German when name already exist.
- Bug fix: Parallel check for Dinamo block linking does not always work correctly when driving turning loop.
- Do not put invisible control characters in XML unless it is a CR, LF or TAB.
- Accessory refresh for DCC generator.
- Transfer table can be released with Shift+Alt.
- Bug fix: When sending aspect do not also send normal switching command.
Re: iTrain Versie 3.2.5
Dank voor de melding.
Nieuwe juist binnen getrokken.
