Reinigingsthinner
Gestart door Willem E zondag 29 september 2013, 17:05:30
Reinigingsthinner
Ooit.....
Reinigingsthinner
Via een ander modelbouwforum kreeg ik een tip:
Schoonmaak-thinner.
Niet geschikt als verdunner of zo, maar wel prima om verf te verwijderen en het tast plastic niet aan.
Heb het zelf nog niet getest en het is o.a. verkrijgbaar bij Hornbach...
Misschien iemand die wél al het gebruikt heeft?
Eventueel kan ik zijn foto's bijplaatsen.
Zie hieronder de enthousiaste tekst:
"Purely by chance I discovered the wonderful properties of a new Dutch
product : Cleaning Thinner.
Go to their website to read more about it.
I needed a powerful thinner (tolueen or xyleen and isobutanol based) to make
my own glue. However,this new thinner did not seem to mix at all with my old
thinner. I tried to use it as a normal paint thinner, but the results were
very poor at best. One liter costs about 8.50 euros, so throwing it away was
not an option. Maybe I could use it for something else...??!! I tried to
dissolve some plastic with it. After all, I needed it to make glue. To my
amazement it did not affect the plastic AT ALL !!! But it DID dissolve both
enamels and acrylics..... Bingo ! Let's find an old model and cover it with
this new product. Wow....the paint started to curl up from the plastic, in
under 15 minutes. I think I found the ideal paint remover. Both enamels and
acrylics can be removed. Especially acrylics dissolve before your eyes. This
thinner does evaporate too quickly, so one or two layers of toilet paper or
a tissue, then soaked, will keep the paint wet enough to be dissolved. After
wetting the paper, GENTLY push it into all corners to make sure all paint
stays wet. Tearing the paper will cause that part to get dry again. Paint
will not dissolve there.
Some info about this product :
- clear transparent liquid, thicker than water
- almost odourless
- non flammable
- does not affect plastic or rubber in any way
- in combination with paper tissues makes it the ideal paint remover for
scale models
- next to none harmfull effects on hands and nose (unlike chlorine, for
instance)
- water soluble, can be rinsed under the tap
- removes both acrylics and enamels
Note: for some reason this liquid has great difficulty removing metallics
such as silver and gold. It takes much longer and it leaves a shiny, spotted
layer.
The characteristics of this liquid also makes it the ideal airbrush cleaner.
My old, dirty Badger airbrush, not used for many years, came out almost like
new, after a 30 min. soak. That hard, next to impossible to remove paint
just fell off, or could be removed with a tooth pick. I could NOT believe my
eyes..... I have tried a large variety of products, but NONE of them could
clean my airbrushes as well and fast as this Cleaning Thinner. Even
expensive Airbrush Cleaner is rubbish compared to this stuff....really !
I spray my models with enamels and acrylics and therfor use a variety of
thinners and cleaning liquids. Turpentine, white spirit, 70 and 96% alcohol,
brush cleaners, etc... etc.... you name it, I've used it. But none of them
work as well as this liquid. I just had to let you know.
The big question for you guys is : where can we get this Cleaning
Thinner....??!!In the Netherlands you can find it in many stores, the brand
is De Parel (www.pearlpaint.nl)."
Re: Reinigingsthinner
werk inderdaad perfect. Heb een fles gekocht bij de bouwmarkt omdat ik nog een kunststof kapje moest schoonmaken. Dit kapje in een bad reinigingsthinner gelegd en de verf loste perfect op terwijl het kunststof niet werd aangetast. het ruikt ook niet. Bedankt voor de tip.
Piet
Ooit.....
Graag gedaan Piet!
Ik zal het doorgeven aan Eric, die dit produkt aanduidde.
Jij hebt het kapje in een badje gelegd. Eric gaf aan dat het spul snel verdampt en hij daarom de boel heeft bedekt met in de thinner gedrenkte tissues. Hoe ging dat bij jou?
Nu hoop ik nog veel gebruikersreacties te krijgen, waarmee iedereen zijn voordeel kan doen.
Hallo Willem,
Met die verdamping valt het reuze mee ik heb het kapje in een open badje gelegd zo ongeveer een half uurtje en de verf ging keurig los zitten leek wel of ik er verf afbijt had opgesmeerd de verflaag ging rimpelen en liet zich daarna onder lauw stomend water met een borsteltje prima verwijderen.
Piet
"Wonder"middel ?
Ooit.....
"Wonder"middel ?
Even terugkomen op dit spul:
Zo weinig over te horen en gelezen maar het lijkt toch bijna een 'wonder'middel :-)
Vandaag had ik een paar Lima's onder handen.
Het waren zoveelste-handjes en verkeerden in een wat vuile vettige toestand.
Rigoreus aan de gang gegaan met onvetter en allesreininger. Nou schoon werden ze!
En nog nat zagen ze er prima uit.
Maar de teleurstelling volgde toen ze droog waren..: 'Wat zien ik? Vlekken! Vlekken!
(En voor de ouderen: er volgde geen tik van Ronnie Bierman... >:-D )
Zo dus:
De hoop was dat dit 'slechts' droogvlekken waren en dus met een vochtige doek wel weggepoetst konden worden.
Niet dus... Wasbenzine? Ook niet... Terpentine? Weer niet... Thinner? Maar niet geprobeerd.
Toen dacht ik aan de schoonmaakthinner!
En zie, dat werkte:
Al zijn er wel enige opmerkingen bij te maken.
Eerstens: gebruik een licht bevochtigde zachte doek. Ik heb wat spul op een doekje gedaan en even laten liggen.
Dit is wat het gevolg is van een te natte doek en veel schoonmaakthinner:
De verf vliegt eraf! Te snel en gemakkelijk dus...
Tegelijk kan je zien dat de Lima op het zwarte plastic eerst de rode verf/print deed en daarna het lichtbeige.
Je zou andersom verwachten... :?
Te voelen is dat de thinner de verf oplost. Direct na de poetserij voel het zelfs wat 'pikkerig' aan, net als bijna droge verf.
Dus niet beetpakken op de net behandelde plekken!
Werk kleur voor kleur af.
Op de doek blijft ook wat kleur/verf achter dus bedenk maar wat er gebeurt als je rood en wit tegelijk doet...
Nu ga ik de kaalgepoetste plek weer bijwerken en nog enkele andere schadetjes herstellen.
Volgende test wordt het ontverven van een hondekop. :thumbup:
markok
Hallo Willem,
Vraagje: waar is dit goedje verkoop?
Mvgr Rick
Hallo Rick,
Ik heb dit spul gewoon in de plaatselijke bouwmarkt gekocht. Ze verkochten allemaal producten van De Parel
Piet
Een tijdje geleden op- een andere site ook wat gelezen over reinigingsthinner.
Ik wilde dat spul ook eens proberen.
Dus ging ik naar de plaatselijke Fixxet winkel hier in Woerden.
De meneer die mij hielp had er nog nooit van gehoord.
Maar ging even op de computer kijken.
Dat spul bestaat niet zei de meneer tegen mij.
Dat is gewoon thinner zei hij maar ik bleef volhouden dat het geen gewone thinner was.
Hij wilde mij gewone thinner aansmeren en er ontstond een heftige discussie.
Wat jij bedoelt bestaat niet snauwde hij mij toe schoonmaakthinner is een goedkope verkoop truc volgens hem.
Ben toen maar snel weggegaan naar de praxis daar hadden ze het wel.
Ik vind het goed spul.
nobody
Vriendelijke meneer zeg.  "Reinigingsthinner" in Google levert 2480 hits.
Dat heet: Klantenbinding... :(
Ik wilde een link van Google afbeeldingen plaatsen. Url kopieëren en hier plakken. Doch dat werkt niet meer sinds
de servermigratie.
Edit nobody: Tweede alinea toegevoegd.
Hier de link voor de reinigingsthinner.
Piet
nobody
Citaat van: nobody op dinsdag 07 januari 2014, 09:35:24
de servermigratie.
Werkt weer :important:
Gerepareerd door forumtechneuten. Bedankt. :thumbup:
