ik ben trouwens wel benieuwd naar het rooksysteem wat "gekoppeld" is aan de slagen van de cilinders:"PROTO-SOUND 3E+
For those who have operated Marklin HO AC 3-rail trains in the past, choosing any of
the Proto-Sound 3E+ models featured in this catalog will give you an opportunity to
run sound-equipped North American prototypes on your railroad with your Marklin
Motorola 1 and 2 systems and any DCC command control system.
Outfitted with NEM 340 wheels and NEM 360 couplers, each of these engines feature an all-new version of Proto-Sound 3.0, contain a third rail sliding shoe for use with Marklin HO stud rail and can operate on AC power.
Like their 3.0 counterparts, Proto-Sound 3E+ locomotives feature full
digital sound,
synchronized puffing smoke timed to the locomotive?s drive wheel? revolutions, speed control, 28 DCC functions*, hundreds of DCS sounds and features**and a command control receiver for use with Marklin DCC control systems.
Each die-cast steam locomotive is intricately detailed to reflect the prototype?s uniquelook. The balanced 12-volt, 5-pole precision skewed flywheel equipped motor ensures that these locomotives will be the smoothest running engines on your roster. And now, thanks to Proto-Sound 3E+, they?ll be the most fun to hear and control as well. * Requires any DCC controller"
Zie ook de brochure:
http://www.mthtrains.com/sites/default/files/europe_2010/2011_mth_euro.pdf
